2020 telluride TPMS reset
shaner154
Calgary
I have a 2020 Telluride that had a low tire. The error light lit up and so I filled the tire and manually checked it with a Guage. Error light is still on and I can't find a reset button anywhere. Not under the steering wheel and not in the glove box. Can anybody help?
SW MO
There’s no reset button. The reset procedure is to fill the offending tire to the recommended cold pressure (or higher). That’s 35 psi for the Telluride, as you’ll see listed on the placard in your driver door jamb. Do that, drive for a minute for it to register, and you’re set.
