Cooling fan draining battery
geegee502
Orlando
Hi there - original owner of 2020 EX Telluride, 50K miles, still under warranty. Recently discovered the cooling fan randomly starts about 2 minutes after car is turned off. Revs at high speed and runs for hours. Ran all night in the garage and drained the battery. Has happened 3 times. Took it to dealer, they can't replicate it, so won't fix it. Has anyone experienced this? How can we get the dealership to fix it without replicating the problem?
Problem with the cooling fan randomly starting after turning off the car, quite annoying I had in a similar situation. In such cases, it is helpful to document each incident, including the time and date the fan starts, to provide the dealer with more accurate information. You can also request that the dealer perform service using diagnostic tools to identify any hidden problems.
yupbtb
Atlanta
2021 telluride and this happened to me as well. Fan wouldn’t stop and had to unplug battery. It killed my fan and the car started overheating. Warrantee repair replaced fan and thermostat. Within two weeks of repair, went to garage and fan was running full blast 8 hours after I parked the car. Dealer is taking it in again next week for the third time. Frustrating and will prob sell it back and buy a non kia vehicle. Seems they can’t find the cause.
yupbtb
Atlanta
I should also add this started happening right at 50,000 miles just as the previous author stated. Software glitch???
