- Messages
- 13
- Likes
- 4
I had some issues with the ISG not turning off the engine a few times this week, had to confirm in manual that it wasn't faulty. Figured I'd share it here for others who may be interested
When the engine stops automatically by ISG, the engine will restart if one of the following driver actions.
The engine will also restart automatically without any driver actions if the following occurs:
Operating conditions
The ISG will operate under the following condition:
ISG Malfunction
The ISG may not operate when an ISG related sensor or system error occurs.
The following will happen:
If the AGM battery is reconnected or replaced, ISG function will not operate immediately. If you want to use the ISG function, the battery sensor needs to be calibrated for approximately 4 hours with the ignition off. After calibration, turn the engine on and off 2 or 3 times.
Prerequisites to reactivate the battery sensor
Keep the engine in the OFF status for 4 hours, and attempt to restart the engine 3 to 4 times for the battery sensor reactivation.
Pay extreme caution not to connect any accessories (i.e. navigation and black box) to the vehicle with the engine in the OFF status. If not, the battery sensor may not be reactivated.
The ISG system may not operate in the following situations.
- Release the brake pedal.
- Move the shift gear to the R (Reverse) position or the Manual mode while depressing the brake pedal.
- The fan speed of manual climate control system is set above the 3rd position when the air conditioning is on.
- The fan speed of automatic climate control system is set above the 5th position when the air conditioning is on.
- When a certain amount of time has passed with the climate control system on.
- When the defroster is on.
- The brake vacuum pressure is low.
- The battery charging status is low.
- The vehicle speed exceeds 1 mph (1 km/h).
- Engine is turned off by Auto Stop for a long time.
- If you unfasten the seat belt or open the driver's door while depressing the brake pedal
- The driver's seat belt is fastened.
- The driver's door and engine hood are closed.
- The brake vacuum pressure is adequate.
- The battery is sufficiently charged.
- The outside temperature is between 14 /F to 95 /F (-10 /C to 35 /C).
- The engine coolant temperature is not too low.
- If the ISG system does not meet the operation condition, the ISG system is deactivated. The light on the ISG OFF button will illuminate and a message "Auto Stop conditions not met" will appear on the LCD display.
- If the light or warning message comes on continuously, please check the operation condition.
ISG Malfunction
- The yellow AUTO STOP (A) indicator on the instrument cluster will stay on after blinking for 5 seconds.
- The light on the ISG OFF button will illuminate.
- There is a malfunction with the ISG system.
- The battery is weak.
- 2
- Show All
