Lance
Sacramento, CA, USA
Upgraded tires and rims and “2 lift kit Also for fun sprayed the brake calipers red. 😊 265/65/17. XD 822 Monsters with -12 off set F3407BDB-19E5-4F0E-855A-B06AED949DB8.jpeg AE72E2AD-F8E6-46E0-8715-41E1DF4301FF.jpeg 659F998F-2718-4885-ABEA-FAFEF57FDA9E.jpeg 1BA656C3-F0B6-4FFD-A9F1-90FD4FAF54AC.jpeg 9C361FC6-8B1D-4AF2-A8B3-14FC82E07337.jpeg 8C2CD601-4A23-4594-A851-DC186216B11C.jpeg 4A599DAA-13F0-4268-B5F0-E20BB9FFA088.jpeg A24709CF-25D3-4529-8C1E-1D1008CCC584.jpeg
Lance
Sacramento, CA, USA
I would say 275 with lift mind you is too much. I have 265 65 and it rubs I had to heat gun and shave a little of the pinch weld to get it to clear.
Landenberg, PA, USA
22x10.5 verde insignia wheels
Arkay, I recognize your license plate from a video with dual exhaust tips. How did you do it? We need more details! The first one being, where did you even source the drivers side exhaust tip that properly mirrored the passenger side one?!
Lance
Sacramento, CA, USA
many plan is 275/40 but urs 65 I think that too much so 40 might not be rubbing
I would ask your near by tire shop they will know what size should fit. I went to American tires and they were great with telling me what would fit or what will be close or barely rub. I’m not sure if your will fit but the /40 is definitely a lot smaller. You could also go to a website that calculates tires size and shows in inches weight and height. Mine are about 31 tall and 10 1/2 wide
Lance
Sacramento, CA, USA
Width ** not weight
Rideutell
Bismarck, ND, USA
Vertini rfs1.7 satin black 22 inch wheels Runnin staggered.
20210410_183315.jpg 20210402_154012.jpg 22x9 fronts wrapped In 245/40/22
22x10.5 rears wrapped in 285/35/22
leedogg
Silver Spring, MD, USA
Will either of these fit my EX? And if so, what tire size should I get?
Bolt Pattern
Diameter
Width
Offset
Centerbore
5x114.3
20"
8.0"
+48
64.1
5x114.3
20"
8.0"
+38
64.1
Rideutell
Bismarck, ND, USA
Bolt Pattern
Diameter
Width
Offset
Centerbore
5x114.3
20"
8.0"
+48
64.1
5x114.3
20"
8.0"
+38
64.1
The 38 offset would fit best. Tirerack.com would be best to choose a correct tire size
leedogg
Ok Tirerack was somewhat limited in recommending tire size. It spat out a list of all my options when I search by 20" diameter. Not sure if width matters or not...
But when I configured a similar wheel/width, it seemed to think 245/50R20 was the size for me. Anybody on 20's using this tire size? Would love to hear how the ride was and see pics.
