Little China
#34
Those Black Rhinos are slick. I’m definitely considering a set of those to replace my EX wheels. I’ve been holding out so far to see what Tirerack will have available. I’m a little surprised that they don’t have their wheel selection available already for the Telluride.
I've been checking every other day too. I think their wheel selection will be similar to that of the Sorento.
#36
So instead of their usual "Market Adjustment" of 5 or 10K Kia of Cerritos can tack on another 2K for the new wheels?
#38
If doing 22", tire circumference may be different which will affect speedometer accuracy. The factory 18 and 20 " wheel/tire set up has the same circumference so no effect on a swap. Maybe
@StephenCantrelle has a dealer response on effect of the 22", if any.
#39
As long as the overall diameter is relatively the same you should be fine. With 22" you'll just have to run lower profile tires.
