I kind of based it off another Telly owner and what he put on his. My dumbness assumed if it worked for him it would work for me. Live n learn.
Unless you get the same exact wheels, size, offset and tires you can't base it from another owner. Even the same tire size can vary from brand to brand. Hopefully some spacers will resolve the problem.
MattyMull
Sellersburg, IN, USA
Makes complete sense. Definitely an oversight on my part. I tend to do things on the fly. I'll post pics once complete. definitely determined :)
MattyMull
Spacers will not solve inside rubbing... If you rub, you rub. Either get smaller tires or shave down the liner. I'm running 32" tires and they rub on the inside with or without spacers... I shaved down the liner and a bit of metal. All good now.
That's gonna be my next move. That's what Kia Service told me to do. Appreciate it.
It's difficult to know for sure where you're rubbing without seeing pictures. Sometimes spacers will work if you're rubbing against the suspension but not so much the liner.
Before shaving down the liner, you might want to try heating up the fender liner enough where you can push it back a bit to see if that helps. It's still not going to look pretty but it's better than to have a hole.
MattyMull
Thank you. I'll try this as well.
Could you post pictures of your T-ride with 32" tires?
