Headlight LED Upgrade
Had to take the bulbs back and swap with a different style. They had little output in pitch black driving
..... I should have waited before pulling the trigger on these.
R
Orange Park, FL
Thread Starter #43
How this new style different?
The four sided bulbs had little output verified by myself and the owner of the business I bought them from. He exchanged them for a two sided traditional LED bulb. In the daylight we could tell the two sided bulbs had way brighter output.
Are these also "custom" made for them? If not, what is the brand and model? Pictures too please. Thanks.
R
Orange Park, FL
Thread Starter #46
They will accept the return. They told me they shipped two sets out yesterday. Just refuse the package when it gets to you
Can't refuse a package that just gets dropped off at your door lol.
R
Orange Park, FL
Thread Starter #48
The new ones the shop gave me. Had to modify the back cover as these suckers run hot started to melt the retainer for the desecant so I removed the retainer as you can see in the pictures. Test run tonight when it gets dark.
The low and high beams use the same bulb right?
kman68
Why can't we just get the bulbs that go in the SX from KIA?
Hogue19
Did you have to modify the housing on the headlight or something on the led bulb itself?
I believe he said he had to remove the retainers so they weren't touching the bulbs. The retainer pictured on the right side normally sits inside the cover.
Hogue19
were you able to close the cover after putting in the new led bulb. Do you think there will be a problem with heat?
