Telluride Bulb Chart for lower trims
Headlamp
Low HB3
High HB3
Turn signal lamp
27/8W 1157NA
Side marker
W5W
Stop lamp
P21/5W
Back up lamp
P21/5W
Rear combination lamp
P21/5W
License plate lamp
W5W
Turn signal lamp
28/8W LL
Map lamp
FESTOON 10w
Room lamp
FESTOON 10w
Vanity mirror lamp
FESTOON 5w
Glove box lamp*
FESTOON 5w
Cargo lamp
FESTOON 10w
CA
Sorry to ask an obvious question.... but j want to take my rear tail light 100% LED
Can you guys tell me exactly what type and how many? Are they all white / amber? Or are any red? Also switching to LED will it shoot any error codes?? I know for my Audi when I switched to LED I got some error codes...
To remove the bulbs in taillight:
  • Open the liftgate.
  • Loosen the lamp assembly retaining screws with a screwdriver.
  • Remove the rear combination lamp assembly from the body of the vehicle.
  • Remove the socket from the assembly by turning the socket counterclockwise until the tabs on the socket align with the slots on the assembly.
  • Remove the bulb from the socket by pressing it in and rotating it counterclockwise until the tabs on the bulb align with the slots in the socket.
  • Insert a new bulb by inserting it into the socket and rotating it until it locks into place.
  • Install the socket in the assembly by aligning the tabs on the socket with the slots in the assembly and turning the socket clockwise.
  • Reinstall the lamp assembly to the body of the vehicle.
CA
Wow seems complex
CA
I see 3 bulbs in the diagram are they the same 21/5w ?
CA
I took a look today to see what effort it would take to remove the bulbs... I dont even see what panels need to be removed to access the tail light????
Looks like it's held on by two screw at the top. Do you have a picture of the lamp assembly with the tail gate open?
