Telluride Bulb Chart for lower trims
CA
#21
I'm contemplating whether or not to do the bulb switch now, or after they replace the tail light... I'm worried they're going to throw out the LEDs when they replace it...
#22
I would just wait.
CA
#23
Stay tuned for a DIY/ HOW to lol
CA
#24
Body shop must have left me a souvenir.
Now this is better than any 3d bulb chart no?
CA
#26
Successful!!! I did a full LED swap!
Super easy! The reverse lights were not easy!
Minotz
Elmira, NY, USA
#28
Can you tell me what LED bulbs you used for the rear turn signal? It says 28/8W LL in the manual but I can’t seem find a bulb that is LED. Thanks
CA
#29
Yes I used the 5w5 led bulb there
Quebec, QC, Canada
#31
[QUOTE = « italsal, poste: 6377, membre: 487 »] Je n'ai pas eu le temps de faire réellement le transfert de l'ampoule, mais semble comme un travail très simple est ici ce que sous le panneau noir
Envoyé de mon SM-G973W utilisant Tapatalk [/ QUOTE]
Merci
CA
#32
Merci
Oui extrêmement simple!
Newark, TX, USA
#33
Is there a specific brand for the 5w5? did you receive those error message after installing the led. I really want to change all of mine but just cant find what has been tested and working.
machtig
Kingsland, GA, USA
#34
If you want bright red lights for tail and brake lights, you should replace with red LEDs; If you use white LEDs for the tail and brake lamps, you lose significant brightness because the lens filters out everything but the red wavelength, which with a white LED, isn't much. Same for amber turn signals, and side markers up front, use amber LEDs. The only place you should use a white LED is the reverse lights.
