Telluride towing package owners
Woodstock, IL, USA
#30
I know this is an older thread - but, thought I'd post this info anyway... FWIW
Good video on how Nivomat shocks work, which are the same concept as the Mando shocks used on the Telluride...
<iframe width="716" height="404" src="
" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
#31
Some more details can be found in this post https://www.kiatelluride.org/threads/how-the-auto-leveling-suspension-works-on-the-telluride.845/
Titanrx8
Orlando, FL, USA
#33
Unrelated question prompted by the photo of the spare tire under mounted. It's been ages since I've owned a vehicle with an undermount, but that one had a hinged bar under the spare which was an effective lever for lowering and raising the spare. Has anyone removed the spare and what do you do to keep it from falling onto you?
Woodstock, IL, USA
#34
I believe it's like my (gasp) minivan of the past... it's a plate under the spare wheel, (close up of a pic from earlier in this thread)
connected to a cable that's lowered by accessing a bolt head inside the hatch which uncoils (for lowering) or coils (for raising the wheel). The cable on the minivan was long enough that when lowered, it was possible to slide the wheel out from under the vehicle - then reassemble in reverse order.
FWIW
Boston, MA, USA
#35
I can't see airbags. Unless I'm missing something. I saw there is a port installed hitch and harness (no air bags). Then EX and higher has the option of factory hitch, harness, airbags. Maybe this is the port installed variation?
The self leveking suspension with hitch is nothing more than fancier shocks that use hydraulics to stiffen ride. The self leveling AIR SUSPENSION is only avsil from factory in top SXP model as an option. That's the one you want to tow with.
Boston, MA, USA
#36
Need to order SXP with air suspension to get that. Its discussed in this article
https://www.caranddriver.com/kia/telluride
Bakersfeld, CA
#40
So here I am too looking to upgrade my EX to Self Leveling. Mine came with the factory tow hitch but no self-leveling. My research has brought me here with the same part numbers. Just looking for confirmation if there was anything else needed or if it was just a straight swap of the strut. Doesn't look like OP has any recent activity in this forum but wondering if anybody else has completed this upgrade.
