2020 Telluride Trip Odometer How do I access it?
Pat
Ooltewah
OK I'm old school and used to the dual trip odometers having a toggle button where the gauges are in plain sight so trying to find out how to use the trip odometer on our telle ? I've looked through the manual and tried googling and used trip odometer in the search function on this forum but guess I'm technically challenged. Boo Hoo poor me right, ok... enough of the pity party. I'm sure there is one and hopefully two trip odometers in one of the menus. Can someone enlighten me on how to bring that up to measure mileage on upcoming trips Thanks in advance
SW MO
Follow this map to get to the correct spot in your gauge cluster. Mode button on your steering wheel takes you between columns, the up and down arrows take you up and down through the columns.
You are looking for ”accumulated info” - that’s your trip odometer. It will not reset until you tell it to. “Drive info” will reset after you have turned your car off for at least four hours. User Settings Master warning.jpeg
