Hey guys,
So, after a bit of reading, I think I may have found the simplest way to convert our 4-pin connector to a 7-pin, and tow trailers with automatic brakes.
You’ll need this for the actual conversion:
https://www.etrailer.com/faq-etbc7.aspx
Then this as you’re wireless brake controller:
https://www.etrailer.com/p-C51180.html
With the combination above, all you really need to do is to run a wire to your battery. 1 wire. That’s it. I’ve seen the YouTube tutorial in which they’ve used a brake controller inside the cabin and a few wires were routed to the battery, back to the cabin, and all the way back to the hitch. Not to mention that this may not even void the warranty (since you didn’t really splice on any of the existing harnesses, like the pedal switch), but don’t quote me on that.
Thoughts?
Johne.
Thoughts?
Johne.
