Side window deflectors part number
I would like to know as well if they are in-channel deflectors. Looks like they are out-channel deflectors though.
Universal City, TX, USA
Easy to install just be careful the rear ones not to be to close to the front door
With the radio off - have you heard any wind noise sound since you installed? I have them and I am trying to track down cause of wind noise on the passenger side that sounds like wind whistling that starts around 45 and increases in pitch with increased speed. Since these were installed before I picked up and drove the vehicle I don’t have a before/after comparison. Thanks
jchropka
Buck Township, PA, USA
The front door guard, where it buts against the trim, did it go over the trim perfectly or does it go on the window. Mine dont fit right over that black triangle trim near the mirror, the guard has no stickey tape just foam on that 2inch downward part. I think it goes against the window....????? is that what i see in your pic?
